configure neighbor-discovery cache max_pending_entries
configure neighbor-discovery cache max_pending_entries max_pending_entries
Description
Configures the maximum number of pending IPv6 neighbor entries.
Syntax Description
max_pending_entries Specifies the maximum number of pending IPv6 neighbor entries. The range is 1 to 4096.
Default
1,024.
Usage Guidelines
None.
The following example sets the maximum number of pending IPv6 neighbor entries to 2,056:
configure neighbor-discovery cache max_pending_entries 2056
This command was first available in ExtremeXOS 12.4.
Per virtual router capability was deprecated in ExtremeXOS 30.1.
Platform Availability
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
